ah youve not got one yet?
well you will be soon up and running m8 when it arrives its an excellent forum and you will get all the help you need
just stay around when your finished
Yeah no worries, it seems the scene is always changing and more stuff to learn and do. thanks again. Rooney to score two v everton!
once a blue always a red once a blue always a red!
thanks for this guide.
cant get into box with ftp so will try this method
where can I get this Image File (.img)?
TKS
Required
* Null Modem Cable (this is NOT the same as a serial or rs232 cable, although it looks the same)
* Image File (.img)
* DreamUp Program
have a look in this thread http://www.digital-kaos.co.uk/forums...00-c-s-t-3872/
Is it possible to install some language packs for this image?
Many thanks for the dreamup guide.I now know I have been using the wrong cable. I will try to flash again when I get the null modem cable.
Hi Guys back again,
I got my 500c today from DVBMonkey but the power adapter does,nt work.
So i found an adapter from an old router and it fits ok.I flashed a working image I found on the net and got it working using the instructions on this thread and this fourm.If I want to replace the image with the Digital kaos one do I press flash erase on the Dreamup program or just Flash.I have;nt got around to the fpt bit yet thats why I used a working image,but I plan to do it when I get a crossover cable.
Thanks for all the great info here and will keep you informed on the ftp jobbie......
Don
can anybody help me, ive recently purchased a dreambox dm500c, ive attempted to connect to my cable provider but channels are locked apart from terrestrial channels, by the way im a novis when it comes to this.
hi ..i made a backup by Dreamup saved it ,when i try to load backup -by clicking Flash ,its not there for selection to chose from the folder. saved.why?its not saved like Image file..how i can change that saved folder to image file.
in my Dreamup select image to flash window :file name box:nothing to select.
Files of type: Dreabox Flash images {..bin.img}.
Hi Guys..
If I want to change images do I select flash erase in the Dreamup programe?
Hi, can you tell me how to setup a dreambox 500c for MMDS cable in Babados
hi ya pal! i dint know u can get a cable dreambox??? i tuaght it was only for them big dishes that pick up nearly all the channels in the world.. but if thre is adream box for virg*n then i think i shud get one is there no defrence between eurovox starview??? and the dreambox thanx mate
hi guys, i have a dm 500-c cable box but i use a laptop to connect it via a null cable that has a usb converter on it as my laptop has no 9 pin serial port, when i run the dreamup software it cannot detect the box?
any ideas how to flash it?
thanks.
