the MAF could have a map, but the MAP i dont think so
Hello guys
Does anyone know were is lockated the map for the MAF - MAP inside the flash ?
i want to "play" with the pressure and i have not find yet the location , i suppose that the are two locations..
Thanks guys
WSC
Smart car engineer ,
wsc (4th April, 2013)
Smart 451 with a MAF?
mate do not stick to the words some guys call the MAP-MAF
i think that everyone know what i mean . correct?
There will be maps for both MAP and MAF if equipped.
Pro VAG Petrol Tuning | Pro DPF Removal | MED17 TPRot Removal
i agree mate, do you have any good idea?
if you use winols crack is in diferend adress with original.and some ecu maps are not stable adress.thats is the reason not posible to deactivate map or egr in all ecus .some ecu works with coplete transport chain of all algo.
please post the ori and let us remove any doubts
wsc (8th April, 2013)
flash 451333.rar
@ominimicu,thanks for the replay m8
here is an original dump
ps: here is the two sensors i am looking for into the dump
have you also read the serial ?
you are welcome in PM WSC
seems to bee the 102 hp brabus
wsc (10th April, 2013)
Hello.
In the software you can find 3 pressure sensors referrenced. Umgebungsdruck (atmospheric pressure), Saugrohrdrucksenor (pressure sensor in manifold) and Drucksensor vor Drosselklappe (pressure sensor in front of throttle). Maybe this car has three sensors, or it has one normal and a double sensor. This would make sense as i can see one sensor with 3 pins and one with 4 pins.
manifold pressure is 220hPa, ambient is 120hPa, and pressure in front of throttle is 270hPa. This means you can cover a real boost up to 1.7bar with standard sensors setup.
greetings,
filecloud
