Here is dpf off
Here is dpf off
password please
THIS is your dump dpf off
for all
no pass
Fiat Doblo 1.3mjd DPF M58BW016 no DPF .bin.rar
thank you very much
This damp DTC P2081 sensor temperature catalisator.Thank you
delete to mask
i check chipauto file and for me is not good, i do in different way, not all necessary switch are off in that file
only manual solution work on this type of ecu
Ecu tuning, DPF, EGR and FLAP remove
thanks for the reply
but this file works tested about 7 cars ..
you do not show a switch?
I comfirm Assitutto have swith solution and he working well tested many times.
This be corect solution without DTC ERASE.
assitutto (14th April, 2013)
hmmm
for this issue you have many ways to solve.
- one is what chipauto posted here - it is not the best solution but is working
- other way is to do manually all the stuff for complete DPF-off
so - it is up to the owner of the car or the person who will do the operation what solution will adopt!
If I would do this operation I would do it by edit in manual mode the soft!
the file is processed with Car$oftware, is it true?
