Results 1 to 4 of 4
    pinheiro's Avatar
    Portugal
    Default Automatic closing doors function - A3
    Good afternoon,
    I have a problem with an audi A3, 1999, 110 cv, TDI, usually it automatically closed the doors: after removing the keys from the ignition, left the car with the keys, closed the doors and moving away from it, it automatically locked. Always did this.
    However, since we have changed the battery, this function stopped working.
    Can someone tell me how to reactivate this function through Vag com or VAS.
    Thanks and regards
    Pinheiro
    Dec 2010
    United Kingdom
    Its been a long while since i did this, but off memory you do this:
    VCDS > SELECT CONTROL MODULE > CENTRAL CONVENIENCE > (LONG CODING HELPER) > BYTE 0 - BIT 4
  3. The Following User Says Thank You to j4g3d For This Useful Post:
    pinheiro (6th April, 2013)
    pinheiro's Avatar
    Portugal
    Hi!
    I will try and then report!
    Pinheiro
    tiguan's Avatar
    Not long coding at this Audi A3 (8L) 1999
    check the coding 07
    [35] - Central Locking
    [46] - Comfort System
