Results 1 to 4 of 4
Hybrid View
    Sep 2011
    spain
    Default editing a channel list on pc
    Hi Guys , can anyone tell me how to save an edited channel list done on my pc its for my mum . I have tried to use STBHEditor , and had to change the file to ads from dbs , when I finished editing it I could not save it , and I,ve also tried PVR800-Editor_dbs with the same result .
    I have a blade and its so easy to edit the channel list and save it .
    Hope someone can help me out PLEASE
    May 2012
    s th
    Quote Originally Posted by mikejc01 View Post
    Is there an option to split and merge as there is with alieditor.
    May 2011
    you use 2 tools (stbhd_lan_mm & PVR800-Editor) grab file from box using LANTool this is done by setting ip of box and password click login, you know the rest if you have read the tutorial(send all files to local). Anyway you have grabbed the TP_Prog.dbs which is in the stbhd_lan_mm folder. In that folder rename TP_Prog.dbs to TP_Prog.abs. Now open PVR800-Editor click file (and change file type to .abs) to looking, we looking sthd_lan_mm folder were we have renamed TP_Prog.abs file and double click to select. select user data base ok.click on all satellite and TP_Prog.abs is open to edit after edit you click save select user data base ok. back to stbhd_lan_mm folder where we rename TP_ Prog.abs to .dbs. Now with stbhd_lan_mm tool still open you select TP_Prog.dbs file on the local file side to click on green arrow to sent to box box will restart when finish. best way I know. no need to get up fast but can be slow with mini wifi stick but works every time no fuss.
    Sep 2011
    spain
    Thanks guys for the replys will have a go at it later, thanks walkaton for all that info
