Results 1 to 7 of 7
Thread: laguna
    Default laguna
    Hi i have a problem with laguna phase 2 from 2000 with 1.8 engine ,i put sirius32 from 1.4 engine without immo the car star.i found bin from 29f200 for 1.8 and i need immo off ,i test several solution but not work ......thx in advance
    Mar 2013
    poland
    try this
    is tested solution?
    Shmortz's Avatar
    in the middle of nowhere
    do you have original dump or not? what is the ECU number?
  5. The Following User Says Thank You to Shmortz For This Useful Post:
    zuzuss (14th April, 2013)
    siemens sirius 32n s110130338 8200107212 8200044437 this is from 1.4 ecu
    Shmortz's Avatar
    this is your file off, try it and report, if engine not working good you must find another file or the best find the exact ECU for your engine...
  8. The Following User Says Thank You to Shmortz For This Useful Post:
  9. #7
    thx works.....
