Results 1 to 15 of 27
    kire106ka's Avatar
    Aug 2012
    MACEDONIA
    Post too old deleted
    IF YOU THINK IT'S EXPENCIVE TO HIRE A PROFESSIONAL,WAIT UNTIL YOU HIRE AN AMATEUR
  2. The Following 15 Users Say Thank You to kire106ka For This Useful Post:
    cicko (8th October, 2017), CM7YRE (26th October, 2017), dokso (20th February, 2018), eliah (1st November, 2017), ettaoussi (13th April, 2013), giani03 (24th September, 2013), HaoMisterix (7th March, 2017), jmac200t (13th February, 2017), jnoroeste (27th October, 2017), kuner (18th June, 2017), Meat-Head (14th April, 2013), mexanico1971 (2nd August, 2013), tajtee (29th January, 2018), tepy66 (13th June, 2017), tourettes (20th February, 2018)
  3. #2
    Apr 2013
    thanks for de help
    kire106ka's Avatar
    Aug 2012
    MACEDONIA
    I need to know if these procedure works for some of you a friend confirmed that works on 11... he manage to repair after interface blocket from rostech update
    DK Veteran mishu_b's Avatar
    Land of Choice!
    I can't see Atmega162 dumps.
    Could you please tell us - how we will reprogram the uC? and with what?
    kire106ka's Avatar
    Aug 2012
    MACEDONIA
    deleted too old procedure
  7. The Following 5 Users Say Thank You to kire106ka For This Useful Post:
    julo45 (13th June, 2013), Meat-Head (14th April, 2013), pedritu (17th June, 2017), tajtee (29th January, 2018), tepy66 (13th June, 2017)
  8. #6
    Jun 2013
    ***1089;***1087;***1072;***1089;***1080;***1073;** *1086; ***1086;***1095;***1077;***1085;***1100; ***1087;***1088;***1080;***1075;***1086;***1076;** *1080;***1083;***1086;***1089;***1100;: ***1042;*
  9. #7
    Oct 2016
    Default download of the file
    Hi there,
    I would like to try to repare my cable too. I need to download the files and so I first need to post here...
  10. #8
    Jun 2014
    Quote Originally Posted by kire106ka View Post
    Yes i know that just read the manual i didn't invent these just upload here.
    I follow the manual and stuck on step 13 the program shuts down on my interface.
    I posted here so everyone can try and share experience if these procedure don't work ok byt if it works will be great.
    A friend from who got these repair his vcds 11.09
    Repair process
    Step1: Please ensure that you have installed the VCDS software.
    Step2: Plug your disabled cable to the USB. There maybe be a pop-up window to indicate you to install the driver, for damaged cable, let it be, skip it.
    Step3: Right click "my computer", select " hardware", then "device manager", then "Other device", the " USB device".
    Step4: Right click "USB device", select "properties", select " detail", there will be a line information displayed. VID_xxxx & PID_xxxx, please write down the 4 letters or number for VID and PID.
    Step5: Unplug the cable, select" my computer" --"C:/"--"Ross-Tech"--"VCDS"--"RT-USB.inf".
    Step6: In item [FtdiHw], please add one more line as " %USB\VID_xxxx&PID_xxxx.DeviceDesc%=FTD2XX, USB\VID_xxxx&PID_xxxx", please ensure the four number or alphabets are the same as the ones you write down in step 4.
    Step7: In the end of the text, add one more line as " USB\VID_xxxx&PID_xxxx.DeviceDesc="VAG-COM Compatible USB Interface", the four numbers or alphabets are also the same as the ones you write down in step4.
    Step8: Save "RT-USB.inf" file and then exit.
    Step9: Unplug the cable, and then plug the cable to the USB port. System will indication found new hardware, and will pop up window for driver update. If do not have the pop up window, let it be, Right click "my computer", select " hardware", then "device manager", then "Other device", then right click "USB device", select update drive.
    Step10: Let the driver point to C:/Ross-Tech/VCDS
    Step11: System will search the drive for several seconds, then it will indicate that find the driver and then install it.
    Step12: Open the software "vidpidfix.exe" i sent you. Click "search", there will be indication two lines of information. First " found one device", second "0".
    Step13: Click "0", then click "open", the information will be displayed in he blank dialogue. Click "write default EE data", if success, there will be a pop up information " wirte successful". Then click "ok" and exit.
    Step14: Unplug cable and then plug cable.
    Step15: Just as the step 10, update the drive and let the file point to the file "VCR_CDM 2.00.00" that i send you. There will be a indictaion information that it install completrly.
    step16: Open the file" MProg3.0_Setup.exe". Click" device" and then"scan", if above steps are all well done, there will be information " find one device".
    Step17: Use Mprog2.8.exe to open file " genius vag com ept.ept" that i sent you. Then click "erase", if succeed, there will be a information " successful", and then click " program" , if succeed, there will be a informtion " programmed serial under disabled"
    Step18: Your computer can recognize the cable now and your cable is ready to use.
    Hello people,
    I have a vcds of 12.12.3 and my problem is not ready can.
    here can help me above mentioned solution?
    If not, does anyone know a solution to a problem can not ready?
  11. #9
    Quote Originally Posted by almia View Post
    Hello people,
    Is your car can-ready?
  12. #10
    Jun 2014
    hello paro44
    yes, I have an audi a4 b8 type
    and my vcds is working about half a year on my car now he does not want
    I also put back the date of my laptop, I get a message that date is not korrect.
    to correct date:
    port status: ok
    USB library version: 03.010.19
    usb driver version: 2:06:01
    interface found
    Type: ross-tech hex USB + can
    version: 192
    footer copyright (c) 2011 by hex microsystems pty & ross-tech, llc.
    Status: ready
    k1: ok
    k2: ok
    can: not ready
    This message I get
    any ideas to solve?
  13. #11
    Aug 2016
    it mean the cable is not connected to the car
  14. #12
    Jun 2014
    This message I get when the cable is connected to the car
    and if I do not connect I get a message
    k1: short to ground
    k2: short to ground
    can: not ready
  15. #13
    Feb 2017
    PARIS
    New on this forum, need the file to try to repair my VCDS 10.6. Hope it works
  16. #14
    Feb 2017
    PARIS
    Kire106A , I just want to thank you.
    You're ept works on my
    CHINESE
    cable.
    I've juste adapt it to my VAGCOM :
    Erase the cable with
    FTD2XXST.EXE (http://www.ftdichip.com/Support/Utilities.htm)
    Launch MPROG3.5 (Same link)
    Change ftdi chip, my chip is FT232RL, I've chosen FT232R on MPROG Interface instead of FT232BM
    I reload RTUSB driver from VCDS, test the cable with VCDS, it works
    I've connected on my CAR (AUDI TT MK1 V6), Test the cable, but CAN is not ready, I've FORCED K connection it works for Engine
    I have change my Option to add my new cruise control, it works
    Now I have to resolve the CAN problem
    Also, does somebody have an English Version in 10.6.4 (Chinese Product), I have the tool in french ?
  17. The Following 3 Users Say Thank You to denarg For This Useful Post:
    HaoMisterix (7th March, 2017), ireun (14th March, 2017), kuner (18th June, 2017)
  18. #15
    Dec 2014
    PL
    VCDS 10.6.4 EN.
    If "CAN" is not working. Try another laptop.
    https://zachowajto.pl/!GXPpP4taw9PE/vcds-release-10-6-4-installer-exe
    Slow download
  19. The Following User Says Thank You to Mario6 For This Useful Post:
