Results 1 to 15 of 15
Thread: Help tuning
    Junior Member wolcar's Avatar
    May 2012
    Default Help tuning
    after i made the changes in file the car don't start.
    Somebody can help me ? Here are the files (org+tun)
    Seat.zip
    Jul 2011
    Which file are you flashing? What tool do you use to write? Checksum looks wrong on 2 of the 3 files including the one labelled org, normally you're tool will correct these at least.
    I've not looked at the files, but I'd say checksum is your problem.
    assitutto's Avatar
    May 2009
    Milano, Italy
    why you decrease cold start map?
    adress is eed60
    restor original value and let me know
    Ecu tuning, DPF, EGR and FLAP remove
    May 2012
    i have made the change because the car starting very hard on hot. i think the problem is with checksum! Can help me to fix ?
    assitutto's Avatar
    May 2009
    Milano, Italy
    i replay in other forum
    atea tun files has checksum ok. Not the brightest tuning but checksum ok. tune silviu. has bad checksum.
    Dont a let guys called Silviu tune your car :P
    assitutto's Avatar
    May 2009
    Milano, Italy
    in other forum wolcar says:
    when is on 99% MPPS show an message to contact ..bla, bla, bla!
    so it's mpps bad write
    PS, hi wolcar, i'm zotto on other forum
  8. The Following User Says Thank You to assitutto For This Useful Post:
    wolcar (16th April, 2013)
    ahh..Mpss might have bricked it s ECU.
    Yo wolcar, answer buddy, you managed to write back the ori file? or is your ecu bricked now?
  10. #9
    May 2012
    i write the original file and the car start..., now i try to fix this file
  11. #10
    May 2012
    Default error
    i fix the file but i have this error with mmps, here is the new file
  12. #11
    tuned with titanium of course...and no checksum.
    heres the file repaired... but just so that you know: it s a lousy tune.
    Let me know if you still get errorWinOLS (Seat Altea (mod) - 370804).rar
  13. #12
    May 2012
    please can you tell me how fix the file. in feature i don't want to repeat the mistake! and why is lousy tune ?
  14. #13
    May 2012
    if I open this file with ECM no driver find it. original file is find
  15. #14
    assitutto's Avatar
    May 2009
    Milano, Italy
    it's normal, ecm find driver only on original file
  16. #15
    ecm sucks...it s not complete and does not display all maps, and all factors correctly. it will always show rpmxload. tuning is not so good beacuse not all maps are modified..and dont remeber why, but if i said it...than i m sure io was right
