Here is solution for this car.
"IF YOU THINK PROFESSIONAL PEOPLE COST YOU A LOT, IS BECAUSE YOU DID NOT KNOW HOW MUCH WILL COST YOU AN UNQUALIFIED"
Pm me for password.
sarigol45 (9th July, 2014)
before dpf off, must reset dpf sensor..
I'll try tomorrow and I'll let the results.
Best regards
White smoke all the time may be also faulty injectors .
In my case, there is no white smoke but just dpf fault reappear on dashboard after removing DPF on file and physically
what is the solution to switch this fault
Hi can someone please help remove the dpf from this ecu the dpf had been removed and car has manigment light on lack of power. i tryed with ecusafe and car will not start, put back to old progam and starts ok. is a audi a6 03g906016gc bosch edc 16u31 engine R4 2,0L edc16u31, with M58BW016DB. MPC564. i had to remove ecu from car and read with BDM i tryed fg galletto 2 and kess v2 unabel to read on car , thanks
yarecky3 (19th March, 2017)
This is DPF OFF ,cks is not corrected but BDM will do this in writing.PASS PM
thank you will try and post results.
