Page 1 of 3 123 LastLast
Results 1 to 15 of 33
    west mids, uk
    Default volta works for dpf remove ??
    Will volta software work ok for remove dpf on a 2006 ford c max 1600 peugeot engine?
    I try to regenerate with snap on and with ford IDS but not working.
    thanks, ninja
    DK- The Bogs Dollocks!!!
    NEVER SAY IT CANT BE DONE!!
    The thanks button works wonders!!
    DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
    assitutto's Avatar
    May 2009
    Milano, Italy
    no, it's better use manual solution
    Ecu tuning, DPF, EGR and FLAP remove
    west mids, uk
    I would use a manual solution, but the guy who has done this for me in the past wont answer phone
    I dont do many of this type of job so not too clued up about it.
    ninja
    Post original file
    west mids, uk
    here is file that I read with mpps, when reading flash, do i have to choose correct version?
    I had 3 options of edc 16 3, or 36 or ??
    I choose the first one and it read flash, here it is.......
    ninja
    DK Veteran Artilect's Avatar
    EU
    I have seen many EDC16C34 disabled by MPPS. I would not flash it with this tool if I was with you. Type in search Ford EDC16C34 and you wil se how many people need full BDM
    __________________
    If You Like My Post
    Please use the button on the LEFT side and the button on the RIGHT side.
    Tuning, EGR, DPF, AdBlue, DTC, TVA, Speed Limit, Immo...
    Here is the file with the switch off
    Password sent to PM.
    assitutto's Avatar
    May 2009
    Milano, Italy
    right, mpps don't work good on that ecu,if you don't brick your ecu you lost injector coding
    west mids, uk
    so i need to check if it is edc16c34 first?
    I read flash as edc16c3 I think, what ever the first option is to choose.
    How do I know/check what ecu version it is?
    MPPS did not tell this info.
    thanks, ninja
    Oct 2012
    friend, I do not want to offend you, but check the label on ecu
    It is a edc16c34, but the read was good.
    C3 have 1mb flash, c34 have 2mb flash, yours is 2mb.
    west mids, uk
    do you know where the ecu is on this car, its a **** to get to.
  13. #13
    west mids, uk
    So, what tool can flash this ecu by obd? Any or only BDM?
    Thanks, ninja
  14. #14
    Nio's Avatar
    I always do this ecu on bdm and really good function only with switch off.
    "IF YOU THINK PROFESSIONAL PEOPLE COST YOU A LOT, IS BECAUSE YOU DID NOT KNOW HOW MUCH WILL COST YOU AN UNQUALIFIED"
  15. The Following 2 Users Say Thank You to Nio For This Useful Post:
    dav29200 (20th April, 2013), ninja123 (17th April, 2013)
  16. #15
    west mids, uk
    ok, i dont have bdm, where is best to buy from, i hear lots of rubbish available
    thanks, ninja
