Results 1 to 8 of 8
    motorsportsz's Avatar
    Jun 2012
    Default Edc16u34 problem
    I have a 2007 Audi a6 2.0tdi DPF.
    DPF had been removed and deleted but the previous tuner didn't do a very good job. He has also lost the original file. I have got a generic original file of another tuner with DPF deleted but now the engine won't turn over. I also can not read and write over this file. Ignition turns on fine. I have been told the key has always been locked in its ignition
    Anyone else experienced this? What is the problem?
    Cheers
    PRESS THANKS + REP IF MY POST HAS HELPED YOU
    DPF, EGR , ADBLUE, SPEEDLIMIT, LAMBDA, IMMO
    DK Veteran Artilect's Avatar
    EU
    You need BDM to recover your ECU. Its responding to ECU ID with flasher?
    __________________
    If You Like My Post
    Please use the button on the LEFT side and the button on the RIGHT side.
    Tuning, EGR, DPF, AdBlue, DTC, TVA, Speed Limit, Immo...
  3. The Following User Says Thank You to Artilect For This Useful Post:
    motorsportsz (17th April, 2013)
    Jun 2012
    Yes it responds to an ecu id
    you must have flashed a worng file, or bad checksum. Give us info on the ECU to find a proper original file. And first of all wi ll try to write that and get the car running. What flashing tools do you have?
    Babos's Avatar
    Mar 2012
    Bad cheksum!! i see that befor!!
    EU
    Yes bad checksum and seed key messed up by ECUsafe.
    This is work for BDM - operation on table
    bad checksum - car dont start
    seed key messed - cant write or read by BDM (you get some error when try to readout - seed error or wake up error)
    BR
    __________________
    If You Like My Post
    Feb 2013
    sorry for my English
    MAGPro2 test
    ECu info..pls for a new file.
