Need dumps of XC161 CPU and 29F160DB Flash.
Especialy from device real working with UDS-protocol.
FYI. Both dumps can be read in XC161 boot-mode
Nobody has?
If sombody will help i'll can explain how to read dumps from device.
OK explain how to read.
I have 2 VAS5054A interface. One ok and second not ok. Writing only external flash 29LV160 does not help. Please explain how to read XC161. I tried with FlashHit program and interface without success.
Thanks.
This is a waste of time
Impactops
adam28 (14th December, 2014)
Some data and serial number of device is stored in ext. eeprom
Flash without eeprom is nothing
BR
Professional EGR, DPF, CAT, VSA, NOx, ADBlue, DTC solutions here...
I have some flash from VAS5054
Readed from old vas
am29f160read.rar
93c46read.rar
and from unknown vas
5640A ,.zip
29F160DB.zip
93C46.zip
Well, it's not stored in the 29f160, so like I said that is a waste of time. Even if you read the serial eeprom where the serial number is stored, then what? What are you going to change it too? the same to that of the software you have registered to a particular serial? and your going to keep doing this each time you have software registered to a different serial or maybe change it to a genuine serial and try to sell it as a genuine interface??
All of these scams belong to the abu dhabi, JC con men across the road
All software that is serial specific in using the VAS5054 is either modified so that the serial of the interface you want to use is added to the license or modified so that it is not serial specific so that any VAS5054 can be used, that way no mods to the interface are required.
Merry Christmas
Impactops
Excuse me,
The firmware is read by any software,
Dump
and these files to
Who can share the XC161 dump?
ayllon308 (22nd June, 2019)
