Here is dpf correct. Love DK.
"IF YOU THINK PROFESSIONAL PEOPLE COST YOU A LOT, IS BECAUSE YOU DID NOT KNOW HOW MUCH WILL COST YOU AN UNQUALIFIED"
Is only 1 byte switch m8...
good solution is not only 1 bit switch...have you correct checksum?
Is not possible to burn ecu writing it. How did you connect BDM adapter? If ecu does not connection to bdm i think is burned. Assitutto has right, is 2 bytes.BR.
I think this is bdm read protection winols do this in default settings.
Maybe i wrong but this is 5 time when i see after use winols and bdm
Car have problem! Simple: cant conected to bdm!!!
Best regards.
Babos.
maybe jano have connected bdm in wrong mode and burn his ecu
Nio (20th April, 2013)
