i have this 2 file, different HW number but same SW version
Ecu tuning, DPF, EGR and FLAP remove
gejzaslapka (18th April, 2013), MAYQUAD (4th November, 2014)
Thank you, i did DPF OFF, but i read this ECU with magpro x17 as EDC16 all gone well, but when writing modified file back some error occured and ecu is dead. then i found that the ECU is EDC16CP35 ......now it is too late
Hi i need DPF OFF e60 3.0td EDC16C35 Bosh 0281014437 1037500755. Read this ECU with Gallett0 3 by OBD THX
maciej (13th November, 2014)
Thanks for the file but the owner decided to buy a new DPF
I have same problem with edc16c35.I write with kess and got error.Ecu dead.But the problem cant use used ecu because cant flash the dump of the processor.Must buy new ecu from factory...
no advertising in sigs !!!
