Seems a bad reading to me.
he has plcc32 ecu, you need a 256kb file. join the 2 hi and low files, or read high and low, and i ll join them
Sorry for my mistake. This file is good.
Sorry for my english, I'm learning everyday.
I'm not sharing passwords, write your thread, and send me link on PM. If I can help. Let me help.
Read again.No good file.
I have two chip B58 911 and I read like 27c1001 with Wellon VP-590, maybe something I do wrong ?
Maybe, this last reading seems a repetitive pattern, so there may be some problem in contacts or chip type selection.
I tried select another type and another program (Willem) and I have this same. When I read again and again all time I have another file. Maybe this chip is broken ? This is not my first time. I desolder chip with temp 300''C put in programer. Nothing else. Car start normal, don't have problem with DTC.
If car starts with that chips on socket then are not broken. Problem maybe your programmers or the PC you are using with them. The truth is that the file you upload here is not good.
wwa (22nd April, 2013)
I tried on another PC and programmers. Whatever. I must replaced this eprom at 28F001, maybe someone have good dump with fix hot start ? Engine AGR.
