Page 6 of 7 FirstFirst 1234567 LastLast
Results 76 to 90 of 102
  1. #76
    Jan 2019
    Somewhere between Continents
    Quote Originally Posted by johnnype View Post
    I use the BDM method for CEM 99-04, no problems at all to change between different types of flash. Homebuilt parallel interface with old computer and BD32 from Motorola.
    Wrote a few MC68376 Assembler programs that I upload to reflash the 28F Works like a charm and easy soldering, 7points under the box!
    But I would be very interested in the virgin file, is it the same image for any model year 99-04 ?
    Hello there. i know this is old, but could you tell me what software did you use to read/write the 28F400 chips?
    I´m trying to read a volvo cem and i need to see if with the parallel interface connections i can read/write... but i dont know what software to use...
    Hope you can help.
    Just Consider helping Freely like I want to do...
    Thanks and Rep are Always Welcome...
  2. #77
    Nov 2019
    If the 28F400 chip only contains the necessary data, what is stopping someone from desoldering the 28F400 chip from the damaged CEM unit, and soldering it into the replacement? Assuming both modules carry the same chip, is cloning necessary or can the chip simply be installed in another unit? Thanks
  3. #78
    RIMKACHIP's Avatar
    Feb 2012
    Hi all, I have problem with cem Volvo S80. In hot condition CEM lost communication and car not start. Just wait cold and start restart. I changed 28F400 MITRONICS for replace with INTEL. Now car have problem when I start car and stop it after 3 minutes CEM lost communication. Need to do ignition on and off for wake CEM. But 3 minutes after using car. I think 28f400 intel is not same at microtronics.
    Original 28f400 is 28F400B5 and new chip is INTEL 28F400BXT120. If anyone can help me it will be good because my customer is furious.
    Envoyé de mon iPhone en utilisant Tapatalk
  4. #79
    Holtek's Avatar
    CEM 08688513 - You must repace CEM
  5. The Following User Says Thank You to Holtek For This Useful Post:
    RIMKACHIP (14th November, 2019)
  6. #80
    RIMKACHIP's Avatar
    Feb 2012
    Quote Originally Posted by Holtek View Post
    I already changed it first time but same problem on hot condition (57 degres). Since I changed 28f400 no problem on hot condition but problem for starting car. I think 28f400 intel has not same. Power latch 3 minutes. If anyone have information of datasheet between intel AB28F400B5B80 and intel PA28F400BXT120. Thanks
  7. #81
    Holtek's Avatar
    The CEM number must match. If you use another number - then it won't work.
  8. The Following User Says Thank You to Holtek For This Useful Post:
  9. #82
    RIMKACHIP's Avatar
    Feb 2012
    Same model same reference just 28f400 intel and not MT for repair hot condition.
  10. #83
    Jan 2019
    Hello guys,
    So, i was able to read the CEM data (Thanks to Holtek for info on programmer and all the Support) and program / add 2 new transponder keys with CarProg.
    I had a problem with CEM making a constant sound like a relay working, but it seems to be related to the "Write" process. I programed again CEM and its all ok.
    But after connection to the car, i have no communication in OBD2 with none of the Car Modules... (ECU/TCM/CEM, ABS, etc...)
    Does anyone know what could be the issue?
    We tried to turn on the car, and it gives signal, but car has no spark. Fuel pump seems to be working because in Injectors Rail, we have gasoline "coming out" (if we open "valve")
    Also, there is nothing in the Dash showing and all the door, windows, sunroof controls dot work...
    Only thing that works is AC and Stereo...
    Does anyone have any idea what could this be?
    Can this be CEM related?
    I was able to get a used CEM but they are different part numbers... Can i just program New CEM with the bin y prepared with the transponders and check it out?
    If anyone has any ideas, i would appreciate...
  11. #84
    RIMKACHIP's Avatar
    Feb 2012
    Quote Originally Posted by boxsport View Post
    Hello guys,
    What is your chip ? 28f400 mt or intel ? With pinout connection or disolder it ? Thanks
  12. The Following User Says Thank You to RIMKACHIP For This Useful Post:
    boxsport (20th November, 2019)
  13. #85
    Jan 2019
    Quote Originally Posted by RIMKACHIP View Post
    Hello.
    The chip is an Intel 28F400 chip
    I used the USB BDM tool to read/write the chip
  14. The Following User Says Thank You to boxsport For This Useful Post:
    RIMKACHIP (5th December, 2019)
  15. #86
    Sep 2019
    Hello, I'm trying to read flash from CEM 08688513 (Micron flash) using usb BDM method. Using TCEM04.xml config file, it doesn't recognise the flash so I can't read it. I have used same device and config file to successfully read another CEM (HW PN 9452596) with Intel flash. CAn anyone help?
  16. #87
    Jan 2019
    Quote Originally Posted by bjp46 View Post
    Have you tried the Volvo config file that comes with the software?
    I only had read the Intel flash, so i cant give you much help...
    Try to speak with user Holtek.
    He helped me and imI pretty sure he can help you on this...
    Did you check if its your cables connection to the pcb?
  17. #88
    rob h's Avatar
    May 2011
    HW number: 9452553 Cem
    Could someone make this file virgin or give the pin code.
    9452553 28F400.rar
  18. #89
    Jun 2012
    Hello! I have a V70 2.4 2001 gasoline but CEM Flash is broken.
    I can't read, I need your help with this.
    Have a nice day
    chassis YV1SW61S932289832
    HW PN 08688434
    Would you like to send it to me if you have a V70 cem 2.4 file?
    best regards
  19. #90
    Dec 2010
    Default xc90 volvo cem configuration
    Hello friends, I have a 2003 Volvo XC90. Defective CEM no ignition and flash corupted . I have another used Cem.
    someone help me with the cem configuration RHD in LHD and manual in automatic gearbox aw50
