send your dump and I will repair it
giegaand1 (23rd October, 2021)
thank you, files in attachment
Hit like and thanks if I've helped you!!
Work HARD and never never never give UP !!!
what is your problem?
ecu lost sync?
post also what eeprom is it............
need help
now my goal is to buy xp-005
who will help?
Any idea why the car wont start. It is a volvo v70 2002 d5, all keys lost. Add the key using org carprog, no start. Vida shows immo status - start not permitted, the car dont see transponder at all. Synchro with ecu - sometimes positive, sometimes negative. Took cem to pro key maker, he did two other new transponders and same, wont start. Vida shows that ID from cem received, but still doesnt see transponder, start not permitted. i tryied to do "restore cem data" using synchronization utility, still same errors. Vida as well shows wrong transponder error. transponder is original ID48 megamos non locked, tryied 3 new transponders. Other thing, when reading cem pulled out of the car, cem info is different from what i wrote in to it. Damaged CEM module? tryied to swap antenna ring, still doesnt work, checked all signals according to Vida, all good.
CEM mc68376 28f400 intel HW 8645716, 8676284, 01W432, S/N 000001547138
EEPROM 95P08 5P08C3 ST3408
ECU BOSCH 0281010319, 08667710 A, HT.2
Not correct information! All black blocks are not CEMs, but REMs (Rear Electronic Module)!!!!
Hi, I have a question.
Is there anyone able to do a synchronization on the V40 BOSCH ME9.0 cem 1K79X?
where are the dumps?
dawidhubert (13th May, 2022)
CEM ECM and ABS ID.
OKAY.
I'll find some time to do it.
Please.
Files.All attached.
Thank you in advance.
