Results 1 to 5 of 5
    Mar 2009
    Default What best image and EMU for newbie????
    Hi every one, Just new to DB, I have a 500S,
    After a lot of reading I have installed Gemini image and tried to install CCCam as EMU.
    After completing the installation if I use my sky card in the DB I cannot see even the channel I'm paying subscription for!!
    Can anyone advice about what easiest to use image +EMU???
    Step
    V.I.P. Member firestorm's Avatar
    Jul 2008
    whom
    hi i would use the nabilo image(I would not trust gemini) and to see a sky card you need to use Newcs cam
    If you tremble with indignation at every injustice then you are a comrade of mine
    Mar 2009
    Thanks I'll try it!
    Mar 2009
    I think that for starters Nemesis EDG is good.
    Top Poster ces's Avatar
    Mar 2009
    nothing wrong the Gem image..in fact its spot on but only with original stbs.... if you downloaded the emu via the blue panel then you should see your card working ok
    ces
