Results 1 to 15 of 19
    marsete's Avatar
    Oct 2010
    SPAIN
    Default I BROKEN DASH BMW 320 WITH X_PROG...PLEASE HELPME
    Hi friends other day i read dash bmw 320 year 2001 whith x prog,i modify and x-prog in write stop in 10%,i connect in car...car runs and stop,and screen dash:CODE IN.Please is posible send me archive complete of memorie 35080,this dash is Motometer HW:10.0 SW:20.0 DIAG:52H AND:59 BUS:11H CAN:04H,original reference is;0 263 606 271.Please helpme.Thanks and regards
    uk
    you can try this soft an hardware same..you will need to edit vin..
  3. The Following User Says Thank You to raf0468 For This Useful Post:
    marsete (2nd May, 2013)
    batandball's Avatar
    May 2011
    Just do the mileage again ?
    If it works use it
    BatandBall
    Oct 2010
    ''car runs and stop''
    If you mean it starts and cuts off then, the problem is elsewhere, these cars run without a dash.
    swingman26's Avatar
    france 26
    Did you save dump before modify ?
    marsete's Avatar
    Oct 2010
    SPAIN
    Quote Originally Posted by swingman26 View Post
    Hi friend thanks for your response.No backup
    marsete's Avatar
    Oct 2010
    SPAIN
    Quote Originally Posted by sparkz02 View Post
    This car before modyfication,runs perfectly
    dalisman's Avatar
    Jan 2011
    EU
    E46 dont have any immobilizer info in cluster , try to start without cluster and if is not starting read errors from car.
  10. #9
    marsete's Avatar
    Oct 2010
    SPAIN
    Quote Originally Posted by raf0468 View Post
    Please friend reload this file,your file is empty,Thanks and regards
  11. #10
    uk
    sorry forgot to insert..here again..
  12. The Following User Says Thank You to raf0468 For This Useful Post:
    marsete (4th May, 2013)
  13. #11
    batandball's Avatar
    May 2011
    did you try and do mileage again, mileage is in top 2 lines ?
    If it works use it
    BatandBall
  14. #12
    marsete's Avatar
    Oct 2010
    SPAIN
    Hello friends,I have been unsuccessfully trying different dumps,someone has a dump with the same reference as my dash,please is important for me.Thanks and regards
  15. #13
    marsete's Avatar
    Oct 2010
    SPAIN
    I need revival dash,I'm desperate...
  16. #14
    UK
    As stated by a couple of other members..this car will run without the dash plugged in so cannot be an immo fault in dash. The fault must be elswhere and it's just a coincidence that it has appeared now. Read DTC's.
    BR
    if this post was usefull
    please press
    the thanks button
  17. #15
    marsete's Avatar
    Oct 2010
    SPAIN
    Ok,looly,i need full dump for revival dash,this problem is original dump erase.Thanks
