No channels were found with Fast Scan off either?
Here is the bootlog from the box if one of the resident Dbox Geniuses wouldn't mind taking a quick glance to put me out of my misery!!
Thanks in advance!
Thanks in advance!
will verify ELF image, start= 0x800000, size= 162920
verify sig: 262
Branching to 0x40000
U-Boot 1.2.0 (Tuxbox) (Nov 5 2007 - 10:24:09)
CPU: PPC823ZTnnA at 67.200 MHz: 2 kB I-Cache 1 kB D-Cache
*** Warning: CPU Core has Silicon Bugs -- Check the Errata ***
Board: DBOX2, Nokia, BMon V1.0
Watchdog enabled
I2C: ready
DRAM: 32 MB
FLASH: 8 MB
Scanning JFFS2 FS: .. done.
FB: ready
LCD: ready
In: serial
Out: serial
Err: serial
Net: SCC ETHERNET
Options:
1: Console on null
2: Console on ttyS0
3: Console on framebuffer
Select option (1-3), other keys to stop autoboot: 0
### FS (squashfs) loading 'vmlinuz' to 0x100000
### FS load complete: 669732 bytes loaded to 0x100000
.................................................. ............. done
Un-Protected 63 sectors
## Booting image at 00100000 ...
Image Name: dbox2
Image Type: PowerPC Linux Kernel Image (gzip compressed)
Data Size: 669668 Bytes = 654 kB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
Linux version 2.4.35.3-dbox2 (nitr8@jijina.nfye.com) (gcc version 3.4.4) #1 Mon
Nov 5 10:25:31 GMT 2007
On node 0 totalpages: 8192
zone(0): 8192 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: console=ttyS0 root=/dev/mtdblock2 rootfstype=squashfs
Decrementer Frequency = 252000000/60
m8xx_wdt: active wdt found (SWTC: 0xFFFF, SWP: 0x1)
m8xx_wdt: keep-alive trigger installed (PITC: 0x12C0)
Console: colour dummy device 80x25
Calibrating delay loop... 66.96 BogoMIPS
Memory: 30828k available (1144k kernel code, 336k data, 60k init, 0k highmem)
Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)
Inode cache hash table entries: 2048 (order: 2, 16384 bytes)
Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
squashfs: version 3.0 (2006/03/15) Phillip Lougher
i2c-core.o: i2c core module version 2.6.1 (20010830)
i2c-dev.o: i2c /dev entries driver module version 2.6.1 (20010830)
CPM UART driver version 0.04
ttyS0 at 0x0280 is on SMC1 using BRGttyS1 at 0x0380 is on SMC2 using BRG2
pty: 256 Unix98 ptys configured
eth0: CPM ENET Version 0.2.dbox2 on SCC2, 00:50:9c:19:3d:2e
loop: loaded (max 8 devices)
D-Box 2 flash driver (size->0x800000 mem->0x10000000)
D-Box 2 flash memory: Found 2 x16 devices at 0x0 in 32-bit bank
Intel/Sharp Extended Query Table at 0x0035
cfi_cmdset_0001: Erase suspend on write enabled
Creating 6 MTD partitions on "D-Box 2 flash memory":
0x00000000-0x00020000 : "BR bootloader"
0x00020000-0x00040000 : "FLFS (U-Boot)"
0x00040000-0x006a0000 : "root (squashfs)"
0x006a0000-0x00800000 : "var (jffs2)"
0x00020000-0x00800000 : "Flash without bootloader"
0x00000000-0x00800000 : "Complete Flash"
Linux video capture interface: v1.00
mice: PS/2 mouse device common for all mice
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 2048 bind 4096)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
VFS: Mounted root (squashfs filesystem) readonly.
Mounted devfs on /dev
Freeing unused kernel memory: 60k init
init started: BusyBox v1.7.2 (2007-11-05 16:35:30 GMT)
Uniform Multi-Platform E-IDE driver Revision: 7.00beta4-2.4
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
dboxide: $Id: main.c,v 1.11 2007/08/07 09:02:15 dbt Exp $
ide: late registration of driver.
dboxide: activating cs2
dboxide: address space of IDE-Interface is at: 0xc3890000
dboxide: probing dbox2 IDE CPLD: walking bit test failed: 0xfffffffe != 0xfbffff
dc
dboxide: no valid IDE-Interface detected
Journalled Block Device driver loaded
SGI XFS with no debug enabled
mount: mounting /dev/ide/host0/bus0/target0/lun0/part2 on /hdd failed: No such f
ile or directory
event: $Id: event.c,v 1.12 2003/09/30 05:45:38 obi Exp $
Detected STB:
Vendor: Nokia
Model: D-BOX2
[i2c-8xx]: mpc 8xx i2c init
[i2c-8xx]: adapter: 0
$Id: cam.c,v 1.30 2004/01/10 16:36:34 alexw Exp $
$Id: avia_napi.c,v 1.18 2003/11/24 09:53:01 obi Exp $
DVB: registering new adapter (C-Cube AViA GTX/eNX with AViA 500/600).
DVB: VES1820(0): pwm=0x48
DVB: registering frontend 0:0 (VES1820 based DVB-C frontend)...
dvb_i2c_bridge: enabled DVB i2c bridge to PowerPC 8xx I2C adapter
$Id: cam_napi.c,v 1.8 2003/09/30 05:45:34 obi Exp $
avia_av: $Id: avia_av_core.c,v 1.99 2006/01/08 21:36:22 carjay Exp $
avia_av_core: Starting avia_av_wdt thread.
avia_av_event: $Id: avia_av_event.c,v 1.11 2003/10/26 16:32:51 obi Exp $
avia_av_proc: $Id: avia_av_proc.c,v 1.15 2007/07/29 18:14:12 papst Exp $
avia_gt_core: $Id: avia_gt_core.c,v 1.48 2004/12/20 01:01:22 carjay Exp $
avia_gt_core: autodetecting chip type... GTX
avia_gt_gtx: $Id: avia_gt_gtx.c,v 1.24 2003/09/30 05:45:35 obi Exp $
avia_gt_accel: $Id: avia_gt_accel.c,v 1.19 2003/09/30 05:45:35 obi Exp $
avia_gt_dmx: $Id: avia_gt_dmx.c,v 1.210 2004/06/26 16:08:15 carjay Exp $
avia_gt_core: masking unhandled irq reg 1 bit 11
avia_gt_core: masking unhandled irq reg 1 bit 13
avia_gt_ucode: loaded ucode v0014
avia_gt_ucode: ucode section filters disabled.
avia_gt_core: masking unhandled irq reg 0 bit 1
avia_gt_dmx: warning, misaligned queue 0 (is 0xFD200, size 65536), aligning...
avia_gt_core: masking unhandled irq reg 0 bit 6
avia_gt_gv: $Id: avia_gt_gv.c,v 1.39 2004/08/28 16:44:56 carjay Exp $
avia_gt_gv: set_input_size (width=720, height=576)
avia_gt_pcm: $Id: avia_gt_pcm.c,v 1.29 2004/01/29 19:38:20 zwen Exp $
avia_gt_pcm_set_rate(44100)
avia_gt_capture: $Id: avia_gt_capture.c,v 1.32 2003/09/30 05:45:35 obi Exp $
avia_gt_pig: $Id: avia_gt_pig.c,v 1.40 2003/09/30 05:45:35 obi Exp $
avia_gt_vbi: $Id: avia_gt_vbi.c,v 1.26 2003/08/01 17:31:22 obi Exp $
avia_gt_core: Loaded AViA eNX/GTX driver
avia_gt_fb: $Id: avia_gt_fb_core.c,v 1.54 2004/03/17 18:42:18 zwen Exp $
avia_gt_gv: set_input_mode (mode=2)
Console: switching to colour frame buffer device 82x32
avia_gt_fb: fb0: AViA eNX/GTX Framebuffer frame buffer device
lcd.o: init lcd driver module
lcd.o: found KS0713/SED153X lcd interface
avia_gt_lirc: $Id: avia_gt_lirc.c,v 1.14 2003/09/30 05:45:35 obi Exp $
avia_gt_ir: $Id: avia_gt_ir.c,v 1.30 2003/09/30 05:45:35 obi Exp $
avia_oss: $Id: avia_gt_oss.c,v 1.26 2004/05/31 22:56:02 carjay Exp $
avia_gt_v4l2: $Id: avia_gt_v4l2.c,v 1.12 2003/09/30 04:54:03 obi Exp $
avia_av_napi.c: $Id: avia_av_napi.c,v 1.33 2004/03/11 15:30:27 derget Exp $
avia_gt_napi: $Id: avia_gt_napi.c,v 1.203 2005/01/05 05:49:56 carjay Exp $
/etc/init.d/rcS: line 253: cannot create /etc/issue.net: Read-only file system
Starting the automounter
Please press Enter to activate this console. avia_oss: IOCTL: SNDCTL_DSP_SPEED (
arg=44100)
$Id: sectionsd.cpp,v 1.249 2007/10/30 08:48:23 seife Exp $
[sectionsd] Caching max 6000 events
[sectionsd] Caching 14 days
[sectionsd] Caching 6 hours Extended Text
[sectionsd] Events are old 60min after their end time
$Id: zapit.cpp,v 1.402 2007/07/22 14:36:42 dbluelle Exp $
[frontend] uncommitted_switch_mode 0
avia_gt_core: masking unhandled irq reg 0 bit 7
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x01, val == 0x6a, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x02, val == 0x93, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x03, val == 0x1a, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x04, val == 0x12, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x05, val == 0x46, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x06, val == 0x26, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x07, val == 0x1a, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x08, val == 0x43, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x09, val == 0x6a, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x0a, val == 0xaa, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x0b, val == 0xaa, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x0c, val == 0x1e, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x0d, val == 0x85, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x0e, val == 0x43, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x0f, val == 0x20, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x10, val == 0xe0, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x11, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x12, val == 0xa1, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x13, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x14, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x15, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x16, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x17, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x18, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x19, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x1a, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x1b, val == 0x01, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x1c, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x1d, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x1e, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x1f, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x20, val == 0x02, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x21, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x22, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x23, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x24, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x25, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x26, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x27, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x28, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x29, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x2a, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x2b, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x2c, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x2d, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x2e, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x2f, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x30, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x31, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x32, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x33, val == 0x00, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x34, val == 0x40, ret
== -121)
DVB: VES1820(0): ves1820_writereg, writereg error (reg == 0x34, val == 0x48, ret
== -121)
/tmp/currentservices.xml: No such file or directory
$Id: controld.cpp,v 1.127 2007/07/01 08:40:13 dbluelle Exp $
[controld] Boxtype detected: (1, Nokia D-BOX2)
[controld]: ROUTEVIDEO v1 = 5 a1 = 1 v2 = 1 a2 = 1 v3 = 0 a3 = 1 fblk=1
[controld] setting VideoFormat to auto
[yhttpd] Webserver nhttpd/3.1.3 (yhttpd_core/1.2.0)
[LCDFONT] initializing core...
[LCDFONT] adding font /share/fonts/micron.ttf...OK (Micron/Regular)
[LCDFONT] adding font /share/fonts/micron_bold.ttf...OK (Micron/Bold)
[LCDFONT] adding font /share/fonts/pakenham.ttf...OK (Pakenham/Regular)
[LCDFONT] Intializing font cache...
[yhttpd] Webserver starting...
[sectionsd] getUTC: read: Connection timed out
Thanks Fergal! I do have a tuner which was soldered into another Nokia I have (which didn't fix that box's problem and tuner was bought as "100% Working")
If I upload the bootlog from the other box, would you be able to determine if that tuner is ok and maybe see if you can see any thing obvious in the log as to what that box's problem is - the syptoms are not picking up transponders which is why I had the tuner replaced.
Here is the bootlog from the other box I have with a "new" tuner soldered into it - if anyone can spot an obvious problem, I would be grateful for your advice!! Cheers!!
^debug: DDF: Calibrating delay loop... debug: DDF: 67.79 BogoMIPS
debug: BMon V1.0 mID 01
debug: feID 7a gtxID 0b
debug: fpID 5a dsID 01-79.72.1b.07.00.00-0b
debug: HWrev X5 SWrev 0.81
debug: B/Ex/Fl(MB) 32/00/08
WATCHDOG reset enabled
dbox2:root> debug:
BOOTP/TFTP bootstrap loader (v0.3)
debug:
debug: Transmitting BOOTP request via broadcast
debug: Given up BOOTP/TFTP boot
boot net failed
Flash-FS bootstrap loader (v1.5)
Found Flash-FS superblock version 3.1
Found file /root/platform/nokia-dbox2/kernel/os in Flash-FS
debug: Got Block #0036
verify sig: 262
CPU: PPC823ZTnnB2 at 67.200 MHz: 2 kB I-Cache 1 kB D-Cache
Watchdog enabled
I2C: ready
DRAM: 32 MB
FLASH: 8 MB
Scanning JFFS2 FS: . done.
FB: ready
LCD: ready
In: serial
Out: serial
Err: serial
Net: SCC ETHERNET
Options:
1: Console on null
2: Console on ttyS0
Image Name: dbox2
zone(1): 0 pages.
zone(2): 0 pages.
Starting kswapd
eth0: CPM ENET Version 0.2.dbox2 on SCC2, 00:50:9c:1c:83:e3
dboxide: probing dbox2 IDE CPLD: walking bit test failed: 0x00000001 != 0x01e7b1
c5
ile or directory
Detected STB:
Vendor: Nokia
Model: D-BOX2
avia_gt_ucode: loaded ucode v001A
arg=44100)
/var/tuxbox/config/zapit/bouquets.xml: No such file or directory
Fergal, sorry about not attaching the bootlogs!
I have flashed Blade Quad to the second box as advised, here is the second bootlog..........
If I remember correctly, that's a problem with the SEC chipset on the mainboard and not the tuner. I didn't see any errors relating to the tuner. It could also be one of the components around the SEC chip, dry joint on a resistor or capacitor, etc. If you're handy with a soldering iron you could try re-sweating the joints before desoldering the tuner. Worth a go...Code:[camd] CA_SEND_MSG: Remote I/O error
Thanks DF! Tried cleaning and pushing in SEC chip to no avail!
So is there any way to be sure that the SEC chip has gone in the 2nd box? I see that dbox.com have replacements for 25 euros - would a TV repairer be able to replace it if I supplied it and, if so, I suppose it would make sense for him to replace the 3 usual components of the tuner on the 1st box too? That would in theory mean 2 working boxes again - Or would I be better off putting 2nd box tuner into 1st box then binning the rest (minus screen) - Please advise, cheers!
thanks lads
I would not bother you would need expert soldering skills and equipment to replace the sec chip
i would try replacing the BFG94 in the other box first
For what being a one hit grab and run never to be seen again toss*r
i would recommend to change the image i bought a box it look the same but wen i change the image i got all setting back and working ...finger cross
