Results 1 to 15 of 15
    dalisman's Avatar
    Jan 2011
    EU
    Default Golf 7 odometer corection
    Hello
    Did any one know what tool can change km in Golf 7 2012?
  3. The Following User Says Thank You to javyb For This Useful Post:
    newyoga39 (20th May, 2013)
    dalisman's Avatar
    Jan 2011
    EU
    thank you for help, but maybe some other tool becuase if I want to buy it is cost around 4000$ and for only golf 7 is little to much because I had other tools but is not supporting golf 7
    smartymarti's Avatar
    Jan 2011
    cornwall
    Try tu or clone ca prog , as your after one of the attest cars but spend virtually nothing , try these if not then it an investment needed
    All about the Bass
    dalisman's Avatar
    Jan 2011
    EU
    TU is not supporting cars from 2010 also CA orginal cant make golf 7 from 2013, also abritus cant make it .
    davecooper47's Avatar
    Dec 2010
    Smartimarti, I assure you that your sarcasm didn't go unnoticed. Laugh. I nearly s***.
    dalisman's Avatar
    Jan 2011
    EU
    any one know what is inside of this dash ? NEC+24C6 ??
  10. #9
    DK Veteran Carsoft2003's Avatar
    Mar 2011
    Algeria
    I have do many golf6 2013 with my vagprog option 2013 up for Nec+24c64 with codebox and vagprog , with AVDI no ok in the moment.
  11. #10
    Quote Originally Posted by Carsoft2003 View Post
    hi mate how many time need vag prog for do golf6 from 2013 ?
  12. #11
    Mar 2011
    Algeria
    Hi , golf6 match2 with nec +24c64 max 2 minutes and with code-box connected. I have test it in polo silver edition dash VDO year 2013 dot it in 2 minute and ok.
  13. #12
    Maartinj's Avatar
    Nov 2010
    I have do many golf6 2013 with my vagprog option 2013.
    have you ever see dasch from GOLF 7 ?
    Question was for GOLF 7 , not a Golf 6 even made in 2013
  14. #13
    [QUOTE=Maartinj;1963375]have you ever see dasch from GOLF 7 ?
    Question was for GOLF 7 , not a Golf 6 even made in 2013[/
    Deleted deleted
  15. #14
    dalisman's Avatar
    Jan 2011
    EU
    so I see only smelscom can do it.
  16. #15
    dalisman's Avatar
    Jan 2011
    EU
    I check all details and smelecom can do only golf 6 because golf 7 is on nec mcu without eeprom.
