Results 1 to 6 of 6
    tiguan's Avatar
    Sep 2009
    Default Help VCDS Log Passat 3C 2.0 TDI
    Hello DK,
    I have a VCDS LOG Passat 3c 2006 BMP
    and see that the turbo too late or no turbo comes. Do you have any idea what could be the cause here
    kire106ka's Avatar
    Aug 2012
    MACEDONIA
    Have you check the vacum for turbo or elsevere tha't has no leek in vacum system ot vnt on turbo is not stuck working properly check these there is no preasure from turbo
    IF YOU THINK IT'S EXPENCIVE TO HIRE A PROFESSIONAL,WAIT UNTIL YOU HIRE AN AMATEUR
    Senior Member Diagnosticated's Avatar
    Mar 2011
    Quote Originally Posted by tiguan View Post
    Hello DK,
    Is that a driving log. You must drive when logging. The turbo values are a little low but the turbo is working ok.
    Feb 2010
    seems ok to me 2. turbo is working
    tiguan's Avatar
    Sep 2009
    Thanks all
    Car is very slow no power, takes a long time for that has something of power,
    no error DTC why is it so slow.?
    kire106ka's Avatar
    Aug 2012
    MACEDONIA
    Turbo is working byt not inought anyway with these preasure should have power so you should check injectors i have problem with passat 2003 avf engine same problem no dtc injectors were good on tolerance in vag byt when i send them for check they dont inject desired quantity of diesel after repair car was ok.
    What is the history of these problem you are first to repair or costomer was in other placess too maybe somebody else mess with it
