    DK Veteran obnchip's Avatar
    Dec 2010
    Default Citroen C4 1.6hdi edc16 c34 lost injector code's
    Is is possible after flashing the mod file to lose the injector code's?Flashed with fgtech2.I have done some of edc16 c34 ecu but never lose code's....
    Nov 2012
    smartville in front of a OBDplug
    yes it's offten the case that you should loose the injector codes
    you must read the car configuration in eeprom before you try to read and write flash
    you can lost lot more as injector codes
    you can also loose tempomat or speedlimiter and other options
    After flashing, turn off ign, then wait 2 minutes (usually the time it get to turn off odometer backlight). Then turn ign on to start engine. And you will have no problems..
    Dec 2010
    yes i did i was following galletto's instruction's...
    but i did not read before the configuration
    bosch kts can recode it?or only official citroen lexia?
    Mar 2013
    same happen to me, bought a lexia 3, recode injectors , problem solved !
    Above sea-level
    Lexia will help you to solve the problem, but next time just wait 30 minutes before putting the ignition on again and it will be fine. I have faced the same problem with galletto 2 and ohter tools and I found out that when I wait a long time before switching on the ignition the codes will stay fine.
