Results 1 to 15 of 17
    Mar 2009
    coalville
    Default download cdf file
    hi i have a eurovox ex5100 pvr someone flashed the box for me. i have scanned the channels in and got rid of all the double and treble channels etc. can i now save the channels i am left with to a cdf file and how do i do it step by step if someone can help please. its a bit daunting to actually do it the first time. i think i now have the right cables but i do not want to lose the channels i have put in place. i have downloaded a vm cdf file for my area without ~~~~ but have not had the faith to do anything yet. can i add these if i want manually without getting all the other channels uploaded. thanks to everyone
    V.I.P. Member HiTeck's Avatar
    Oct 2008
    satsmo's Avatar
    Jun 2008
    Hi, if you already have your channels sorted to your preference and you want to save them to your pc better to use Voxer. It a small programme that you can use to edit and save your CDF.
    You will find it here Digital Kaos - Downloads - voxer eurovox 1 . 2 installers the help file with the application will help you out, but its easy enough. However if you have a prolem please post back.
    You do not need to download some other person's CDF as you have already sorted your CDF. Regards the ~~~~ channels, you can delete or lock them, but if you scan to update channels they will come back, even if deleted or not contained in your CDF.
    Or do a HiTeck said
    Mar 2009
    coalville
    THANKS FOR THAT. i have a laptop so i have bought an adaptor usb to serial and a null cable i presume not the serial to serial cable i need to use. by the way the best forum site i have come across full credit to all u guys
    Mar 2009
    Agree about the help on forums here, needed some firmware and just a pointing in the right direction on an ex5100 found it easy on here.
    Mar 2009
    coalville
    hi is there anyway i can test my null cable and usb adaptor as it cannot see my eurovox box firmware using something else.i am using com 7 installed drivers with the disk . using voxer i told it which com port but no joy. any ideas
    Oct 2008
    Set it to com 3 via device manager and try again, if your still struggling come back.
    Mar 2009
    coalville
    thanks but i could not put to com 3 said it was used by something else. tried com 2 set on device manager and at other end on volex com2. still did not see eurovox. i purchased cheap cables on e bay. i dont know if its the cables but i think it is a combination of vista which i have and the driver software which said it was compatible to vista but i think that is questionable. i decided after hrs of farting about pc crashing etc to dig an old computer desktop out rigged it up put the serial com cable in and it worked in 30 secs. this pc has xp also i am not using a usb to serial db9 adapter. thank you. i have another question in the volex programe can you take any info from one cdf file and copy and paste it in another cdf file to make a new cdf file. is that possible
    Oct 2008
    Can I ask why you would want to do that?.
    Mar 2009
    coalville
    forget about that volex question .i just thought it might have been easier than organising your channels on the eurovox and then saving the file . but its not. i like the volex file as you can make a print of of the channels. once again thanks for everyones help
    Oct 2008
    Satsmo
    Thanks for the info in Voxer.
    Great programme which has made my life so much easier.
    Thank you.
    Mar 2009
    anyone got a cdf for wirral
  13. #13
    V.I.P. Member camelv's Avatar
    Nov 2008
    dingle ,liverpool
    its the stuff we think we know that stops us all from learning
  14. #14
    Mar 2009
    middlesbrough
    Thanks Hitek great job with the guide cheers
    zee
  15. #15
    Mar 2009
    middlesbrough
    Default cdf files
    Hi im trying to get the cdf files in the download section but it says i have to post on the forum which ive already done any help anyone???
    zee
