in edc16c39 fiat speed limiter is 300km/h
your ducato is limited? what velocity?
I want to limit the speed but inside the flash, not in the eeprom. Does anyone know how?ducato_2.2_120hp_org.zip
Thank you,
S.
Ecu tuning, DPF, EGR and FLAP remove
Limiter is at the limiters per gear. Limit now at 3000RPM
bad read, my fault. You want limit the speed?it's correct?
Can you tell me the address for rpm limiter per gear. That is what i look for. Thank you
