Results 1 to 7 of 7
    Jun 2009
    Default Ondemand plugin error
    I have a solo2 with openpli image
    I installed ondemand plugin from the openpli plugins menu and I get the following error after I install it
    Some plugins are not available
    extensions/ondemand (NO module named lxml)
    it seems to install ok and I have rebooted the box etc
    Many thanks for any help.
    Mar 2011
    Did you manually install the required python plugins:
    python-lxml
    python-beautifulsoup
    python-dnspython
    These plugins may not exist in the OpenPli feed, in which case you'll need to get them elsewhere.
    have a read of this
    aslo the files are here
  3. The Following User Says Thank You to reaper101 For This Useful Post:
    terayon00 (13th May, 2013)
    digicon's Avatar
    Hi Reaper101,
    Please do not post links to other websites with a similar content to DK Thanks http://www.digital-kaos.co.uk/forums...rules-2/#post2 : Do not post links to other forums with similar content
    Please upload them here instead
    Thank you
    Jun 2009
    Thanks reaper got it working. Only 4OD not working
    Jul 2012
    Quote Originally Posted by terayon00 View Post
    Just replace tags with categories in line 197 in 4od py file, reboooot
    Jun 2009
    Quote Originally Posted by frank087234 View Post
    How do you do that exactly?
    Jul 2012
    use DCC to edit 4oD py as above and reboot
