Results 1 to 14 of 14
    soxten's Avatar
    Mar 2013
    Default BSI Peugeot 206 2001 pin out/virgin
    Someone knows how to read and make this virgin?
    peugot 206
    2001
    siemens 9626460880 03 B2
    I don't have Eeprom on the backside of the motherboard...
    verica's Avatar
    MACEDONIA
    you have motorolla mcu on the picture read eeprom from mcu
  3. The Following User Says Thank You to verica For This Useful Post:
    soxten (10th May, 2013)
    soxten's Avatar
    Mar 2013
    Can I read with Xprog?
    (Motorola ZC505911CFN mask:OD60J)
    didi_du_93000's Avatar
    France Paris
    Yes you can use xprog M.
    remove MCU from PCB and put on adapter and read it.
    FULL WORKING.
  6. The Following User Says Thank You to didi_du_93000 For This Useful Post:
    soxten (12th May, 2013)
    soxten's Avatar
    Mar 2013
    I did read MCU ON Xprog HC05 mask 0D60J but the file is only 1kb?
    se dump, is this correct?
  8. #6
    pin code NX25
  9. #7
    soxten's Avatar
    Mar 2013
    Ok, thanks for pin code Koyot!
    but i whant this BSI to get virgin, can you fix?
  10. #8
    verica's Avatar
    MACEDONIA
    fill with 00 00 00 00 all zero
  11. The Following User Says Thank You to verica For This Useful Post:
    soxten (14th May, 2013)
  12. #9
    DK Veteran gtmech's Avatar
    Hell
    Quote Originally Posted by verica View Post
    I dont think that will work on that model mate, if it doesnt soxten, I am doing the same thing on the same BSI and have a virgin file ready to try so if needed then PM me tomorrow and ill get it from my office and send to you
  13. #10
    soxten's Avatar
    Mar 2013
    Gtmech please put our virgin dump here, i gone send my Bsi to diffrent town so I need to know it works!
  14. #11
    DK Veteran haingoben's Avatar
    Dec 2011
    Tana
    hi
    I need to read the same bsi but MCU is not motorola or may be for siemens D9 B3 more small Ac2c00xxxinfineons mcu,how must I can read it!!!!
    ps!I send picture tomorrow
  15. #12
    HeXeN's Avatar
    Mar 2015
    any connection in-circuit? to avoid soldering this old fart.
    edit: desoldering & orange5. quick job.
  16. #13
    Jun 2021
    Quote Originally Posted by didi_du_93000 View Post
    FULL WORKING.
    I link to this old post to ask if the same operation (read and write MCU) can be done with immo killer software and UPA usb adapter without removing MCU from board but just soldering wires to proper pin
    thank you
    Paolo
  17. #14
    Jun 2021
    Quote Originally Posted by gtmech View Post
    Hi gtmech,
    I am having same need to virginize this BSI.
    can you post me the virgin file ?
    thank you
    Paolo
