Results 1 to 5 of 5
    Senior Member makadam's Avatar
    Nov 2010
    EUROPE
    Default 00003 - Control Module: Defective Passat b6 2007
    I have passat with this error on radin-navigation RNS300. This error appear after wrong coding. Unit work just fine but error message can't be erased ! Any solution for this. I try recoding with different option but same error
    Address 37: Navigation Labels: None
    Part No SW: 1K0 035 191 D HW: 1K0 035 191 D
    Component: J401 0111
    Revision: 00015000 Serial number: VWZ1Z2F6278085
    Coding: 0043400
    Shop #: WSC 00028 028 00001
    VCID: 2341EBBF9B45
    1 Fault Found:
    014 - Defective
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 72
    Mileage: 207571 km
    Time Indication: 0
    Date: 2012.12.09
    Time: 00:48:19
    Address 56: Radio Labels: None
    Component: R 0111
    Coding: 0043400
    VCID: 2341EBBF9B45
    1 Fault Found:
    014 - Defective
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 72
    Mileage: 207571 km
    Time Indication: 0
    Date: 2012.12.09
    Time: 00:48:19
    Nov 2010
    EUROPE
    No one have a solution?
    Nov 2010
    EUROPE
    Can someone give me good dump for RNS 300 unit I will try to reflash and then I will try to remove error codes and make new coding even this one is correct. This message appear after I try different coding trying to remove this unit from can gateway. the car has problem with battery discarge, but RNS 300 was not problem it was left door! I want to repair now. The unit works fine without any problems but error message can not be errased !
    dimitar's Avatar
    check vas flash discs for soft update , use ODIS engineering 10 min. job
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  5. The Following User Says Thank You to dimitar For This Useful Post:
    makadam (28th November, 2013)
    Nov 2010
    EUROPE
    Quote Originally Posted by dimitar View Post
    Sent from my GT-I9100P using Tapatalk
    We can't help everyone, but... everyone can help someone!
