Results 1 to 3 of 3
    May 2013
    Estonia
    Default DM7000 freezes while booting
    I have a nearly dead DM7000, which I would like to reanimate. The box freezes immediately after power on, displaying on lcd "Dreambox Multimedia" and Now Booting on TV screen. BUT! If I put the box in a freezer (don't ask my why i did it), it works fine until it warms up to room temperature. So far I was able to start scanning transponders and then it froze again. Flashing the box works only when the box is in the freezer.
    I checked PSU voltages from the HDD power connector, all voltages are OK +12.1V and +5.1V. All caps are fine too - checked them with a ESR meter.
    I'm trying to find a solution the past few weeks, but no luck so far. Any ideas what it cold be?
    Edit:
    All I can get from hyperterminal:
    Installed RAM: 16 MB
    Checking RAM between 0xA0000000 and 0xA0FFFFFF
    System RAM check complete
    trying 1 (1)
    Booting from [FLASH] Application in Flash...
    May 2013
    Estonia
    I installed a new image (gemini 4.7) and now geting this via hyper terminal:
    Dreambox DM7000
    loaded at: 00500000 00615170
    relocated to: 00400000 00515170
    board data at: 00513124 00513170
    relocated to: 00405194 004051E0
    zimage at: 004058D5 00512706
    avail ram: 00516000 00000000
    Linux/PPC load: console=null root=/dev/mtdblock5 rootfstype=squashfs ro
    Uncompressing Linux...oops... out of memory
    pause
    done.
    Now booting the kernel
    Jun 2013
    Hello
    this behavior is not unncommon when there is a small crack in the soldered or printed connections in a piedce of electronic equipment. (Try freezing on crashed harddisks)
    you might want to freeze only parts of thew Dreambox to check where the crack is.
    regards
    Ahellman
