Results 1 to 6 of 6
    Mar 2009
    London
    Default please help to set bridge conection
    Hi guys,
    I have dream 7025 and just got enthernet adapter linksys wet54g.
    I have tryed in many ways to connect it but had no luck.
    When i connect linksys to dream nothing happened i have scanned with DCC and it not recodnised.
    I wonder that linksys wireless faulty? or there is something that i don't know.
    By the way I have bt hub if that makes any different.
    Jul 2008
    Administrator
    Devilfish's Avatar
    Feb 2008
    First of all you need to set up the bridge to communicate with your own router.
    Follow the instructions on the leaflet that came with the bridge and connect it to your PC using an ethernet cable. Access the web interface on your browser, I think the default ip address is 192.168.1.226. From here you will need to set up the wireless to be able to talk to your router. Once that's done, disconnect it from your PC and plug it in somewhere else, doesn't need to be connected to a dreambox, just somewhere else. Now type the ip address of the bridge into your browser on your PC and see if it can connect to the bridge wirelessly - if it can, well done, all the settings are correct. You can now connect it to your dreambox and it should work fine.
    Jun 2008
    You can flash your linksys with DD-WRT.
    After, go to this website, you have all info for configure your bridge
    h**p://w*w.dd-wrt.com/wiki/index.php/Wireless_Bridge
    Nono
    Atlas HD200se F404
    vu+ solo suptv + Ncam for TNT card V5 openpli 4.0
    vu+ zero script openpli 6.2
    Sunray 4 openpli 7.0 suptv
    Mar 2009
    London
    I have done it and when i search for the wireless network in the range on my laptop it apears linksys computer to computer network,when i plug in to the box message comes ip unconfirmed
    nameserver unconfirmed
    Junior Member dehowletts's Avatar
    May 2009
    are you using a linksys router and adapter?
