Results 1 to 11 of 11
    verica's Avatar
    Mar 2010
    MACEDONIA
    Default toyota avensis 2005 info display not working
    toyota avensis 2005 multifunction display is not working i open it didnt find any fuse burnd there is mcu nec 784936agf148 i think that is my problem did any one have saolution for this
    Oct 2012
    I have the same problem,found any solution?
    Jul 2010
    Bulgaria
    Default Solution
    Hi guys, I had the same problem with Avensis 2005 display. It doesnt work at all, blank, no light, no symbols. I try to find solution here but I didnt find anything. Made more research and find some russian sites with info. I already fixed it - so the problem is in one SMD resistor of "0 Om". As I undestand this resistor its like fuse, but let someone with more knowledge to explain how it is works. Ive made some pictures. I hope that will help some Toyota owners!
  4. The Following 9 Users Say Thank You to todorst82 For This Useful Post:
    Botinaa (29th April, 2025), deha123 (29th August, 2024), dunnnia (6th March, 2020), ernesto1670 (20th May, 2020), joaquinmjuan (28th June, 2023), laki23 (7th May, 2022), mitsoras (31st March, 2023), veskobx (14th January, 2021), zayc (9th February, 2025)
    Jul 2021
    I have the same problem with mine, it's completely dead
  6. #5
    Aug 2021
  7. #6
    fuzz1's Avatar
    Jul 2019
    Hehehe
    The zero ohm resistor is really a fuse. If blown don't replace it with solder. If there's another fault there will be more damage.
  8. #7
    Nov 2020
    Alicante, Espaņa
    Quote Originally Posted by todorst82 View Post
    Thanks for the photos and input. It was the resistance. It can be changed well, and as the compi says, I would put another resistor, since it is acting as a fuse. In case it breaks, the screen is in a critical place, and the dashboard can be set on fire. I would put a resistor, or even, you can put a fuse there, but without going too far. I don't know what a current resistor 0603 supports, but if I put a fuse, I would put one at most 0.5A.
    That line, I think, feeds the microprocessor. Therefore, the screen is dead.
    Regards, and thank you very much!!.
  9. #8
    Nov 2020
    Alicante, Espaņa
    Hello, in my case, it is not the resistors, in fact, in the one in question here, 1.6V appears on both sides... I have checked and I have a Display that all the shunt or (0Ohms) resistors are fine. I have marked them with a green oval in the photo. Then, with blue oval, coils that appear 5V. There is one, with a Red oval, that raises the tension a little, and then falls. That tension feeds the screen. Any idea where to look? Thank you!. If you need any measurements, ask me and I'll post it.
    Attachment 1004307
  10. #9
    Mar 2024
    I have the same issue.
    EDIT: Fixed, it was the 0Ohm resistor. Thanks.
  11. #10
    Apr 2025
    Just to confirm this was working on 2003 T25. @todorst82 is a legend
  12. #11
    Nov 2020
    Alicante, Espaņa
    Quote Originally Posted by Botinaa View Post
    Hello, good morning. I've fixed some that had this problem, but sometimes, it can be other resistors. I've repaired several Toyota Yaris dashboards, which are the same piece of junk, and they open or change their value randomly (that is, they're not always the same resistors), causing the dashboard to function partially or not at all. My colleague has provided you with the most common fault, but that doesn't mean it's always the case. Anyway, in electronics, you have to search until you find it. Best regards!
  13. The Following User Says Thank You to joaquinmjuan For This Useful Post:
    fuzz1 (Yesterday)
