Results 1 to 8 of 8
    Default 3bar map sensor Mercedes W203 C200 CDI
    Hello, I have an MB W203 with turbo GT22V and I want to take over 1.5bar boost. Now I have 1.5 bar boost with original 2.5bar map sensor but I want to take over this. I have 3bar map sensor for Mercedes but when I mount him the car goes in limp mode and I want to remove this problem. Whith file made by me I have 180hp in 1.5 bar.
    For 3bar map sensor I need to coding thison the car or to modified some map? If I need to modified some map can someone told me which map is it? If I need to modified some map I think this is 15BE2. If someone can help me I thanks a lot. Sorry for my english.
    Someone can help me? Please. Thanks a lot
    Fec001's Avatar
    I think you need recalibrate MAP sensor linearization in dump. Maybe a pro will lead you to the right direction
    If I know which is the liniarization map I can do this with trying. Thanks a lot
    Netherlands
    Look at 0F3352h
    Quote Originally Posted by easytech View Post
    Look at 0F3352h
    I think this is not ok. You are surrly? Thanks a lot.
    Netherlands
    Yes pretty sure, index is in A/D counts, output in mBar.
    I can't make the car to work with 3bar map sensor... can someone help me? Thanks a lot.
