Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
  1. #16
    Mar 2009
    N.I
    I have tried everything and read lots of post but still can not get this to work my skybox f3 is still stuck on load ?
  2. #17
    Mar 2009
    N.I
    Hiya slik im the same did you ever get anything to work
  3. #18
    P&D's Avatar
    Where did you get to in the tut before having probs ????
  4. #19
    Jan 2012
    Quote Originally Posted by spaceman2009 View Post
    Same for me. I have tried many different .abs files but to no avail. Does anyone know anymore suggestions to try?
  5. #20
    Aug 2013
    gwent, South Wales
    Is there any other software for flashing f5s I am using a usb to null modem. I have windows 8 on laptop have tried different timings with different downloads. Can I dump another f5s I have and install that dump on bricked box? Without it affecting the working box
  6. #21
    P&D's Avatar
    Quote Originally Posted by maundyboy View Post
    There is the problem USB TO NULL CABLE - WINDOWS 8
    XP com port - skybox work's wonders
    Yes you can use the dump file without any problems
  7. #22
    P&D's Avatar
    Quote Originally Posted by tshuma View Post
    Don't load the .abs file
    load a firmware file & tick boot loader
  8. #23
    May 2012
    Quote Originally Posted by P&D View Post
    Your marbles going?
    The firmware is a .abs file when extracted
  9. #24
    P&D's Avatar
    Very true DW...I mean the Eromclients.abs file
  10. #25
    P&D's Avatar
    Have you made a backup of the box before it went tits-up ???
    If not try this backup....always worked for me
  11. #26
    Oct 2015
    Got a set stb memory error
    how to fix someone help tried to use F3S F5S RS232 Upgrade TOOL and the SB.abs file but it doesn't work keeps coming up with stb memory error
  12. #27
    DK Veteran slugworth's Avatar
    Nov 2011
    new england
    turning the receiver on too fast or not using an old pc
