when i go camping could i buy a Huawei 3 wifi dongle and plug it into my laptop and connect a eternal cable up to my dm500 and be able to watch sly or would it be to slow thanks ?
All depend on which dongle you buy the network its connected to and the signal strength of the 3G signal where you are planning to use it but yes it can be done
thanks mate will i have to change the setting on my vu+duo box mate ?
tryed it at home and nothing ive turned on my lapto conected the eternal cable to my vu+ box and get no picture any iders
I am afraid its not just as simple as plugging the dongle into the laptop and then a cable from the laptop into the box you have to make a bridge connection from the laptop to the box
http://www.wikihow.com/Bridge-an-Internet-Connection
tryed that mate but at this point
Create the bridge on the host machine. Go to "Change adapter settings" on the left pane on the host machine. Two or more connections should show up. Highlight both Local Area Connection and Wireless Network Connection. Right click one of the icons you highlighted and an options menu should come up with only "Bridge Connection". Click it and it should take a second to set up the connection
when both highlighted it does not say bridge connection ?
Have you used a crossover cable, i dont think it works with normal ethernet cable
heres how i run mine mate http://www.digital-kaos.co.uk/forums...access-338917/
I've asked our two resident pikeys (Renwich and Satsearching) over on UkCvs to pop in here with some help and advice, as I understand that they've got this sorted out very nicely when they go off caravanning.
Cheers- AL![]()
I use a T-Mobile wireless pointer mifi device, CS does not however work on the T-Mobile network, so I unlocked the mifi device and have a payg 3 sim in it, to save the complicated setup of ICS between the DM and a laptop I use a vonets wireless bridge this wirelessly connected to the mfi works very nicely,but as stated above the ecm response are dependant on signal quality.
In summary
Dm500
Mifi device
3 payg sim
Vonets wireless bridge
PaphosAL (19th May, 2013)
You really should go with a Three account, tried all other networks and Three appears to be the best, others have too much latency.
hi
this is not my work I followed and used with a laptop ( before getting a 3g router)
How to connect dream box using 3g,
1. Connect your USB dongle to computer and connect to the internet.
2. goto run menu and type cmd or
accessories Command Prompt / Programs / start
3. you will get dos command screen
4. type ipconfig
5. You will be given two ip settings, you might see on top 192.168.0.1 or some ip range.
7. Connect your dream box to tv and connect your computer also, if you connect using directly, you should use cross cable to connect your computer.
8. you should share your network connection, to do that
network connections / settings
9. start select your 3G or GPRS connection.
10. click right mouse button and select properties and select advance tab on the dialog box and on the internet connection sharing tab select allow user to share my internet connection
click ok button and close it
Then go to dreambox on the
communication settings / settings /menu is 192.168.0.1 then select your ip as 192.168.0.2 then Set gateway as your computer ip 192.168.0.1 and name server also same ip rest of the things same.
Save it and close
Wait till online comes and try to browse channels
the set up I now use is
dm500 or openbox s9
tp-link 3g router
vonnets or tenda 300m wireless bridge
a three usb dongle pay as you go
hope this may help
