obdmaster (17th June, 2013)
ok oep, carfix.. we are asking people that tested it whether it works or not, not for speculation. We can all speculate on our own, we really don't need you to do it for us. after avdi cas4 dump option dropped from 4k to 2.5k i noticed bmw exp cas4 option dropped from 2500 to 2000... and if clone works good i think they will drop price again that's why i'm asking because i don't want to fork over 4k for ORI just to find out next week they cut the price 50%. Thanks.
20Mhz Intel? 80386 CPU - VGA Graphics - 2 MB RAM (16 MB Capacity) - 60MB HDD - SCO? XENIX?
if you want to buy then go ahead buy why asking people for help when you can buy )))) go ahead buy test post
SEE FOR YOURSELF ... DUDE~!!!
a friend of mine trying to buy one but, still can not you know why?
sellers say it got some bugs please wait untill the factory updates it and we will send it to you.....
This BMW E/F SCANNER in my opinion is way to expensive at ?650 for a clone tool with no updates. At that sort of money you,d be better off to buy original at around ?1500 with E series key programming included then add other things as you need em. Lets face it who,s going to have the balls to try clone on programming CAS4 key, or reading ISN from tricore engine ecu. Could end up a costly exercise if clone screws up customers car. Dont get me wrong it might work great, but theres also a chance it may not, and at ?650 in my opinion with no support its way too expensive to buy one just for testing then to chuck in the bin. The chinese prices of clone tools have gone up and up over past few months, few years back this would of been priced around ?300ish when first released not ?700 like this was.
You need every tool in the book, to do this auto locksmith job.
gwee (17th July, 2013)
hello...............alll
i damage two ecu with this clone.EDC 16 BMW E46 2005 318-i.
dont buy this tool..
digitaltech (8th July, 2013), Fallen (8th July, 2013), gwee (17th July, 2013), obdmaster (7th July, 2013)
[QUOTE=vanos batam;2022983]hello...............alll
dont buy this tool..[/
this device not working with e46 and with other bmw with ews jus with cas . How you read ?
on the table..the ecu same as e90 engine n42
Read using what tool???
hi there, are there updates available to this scanner ? new informations about this tool ? i save some Money to buy an new Toy But i'm a Little bit afraid of buying China clones. the most Scanners are beta Versions and not fully working. the current Version of E/F scanner clone is working in both Systems as well ? e series and f series ? in older post's i read, only e series working.is this Statement actual ? please don't advise me to buy original. too expensive to do a few Jobs. many thanks for a Little Input and bye michael
no one says...
ok dk some1 said he received 13.6.10 updates
don't have much info on how the tool is working really... $1000 too much for a clone for me.
What sucks is the one right before it that did not do E and F. Was 500 and worked 100 percent. DDE/cas matching 100 percent fine,caesung said he could not get older version friend wanted one (they all got reflashed to get double the money). At the price they want for the new clone buy real instead. If you live in europe they get more per key, in the states US you get less takes longer to pay. The ones before reflashed worked fine with autokeys cheap remote bmw keys 32.50 and the emergency key with no button shell and plastic key worked fine in the door (tip once cut on miracle, take space and depth and cut top plastic material off once it gets wear you can jiggle to get it to work.)
acardi (11th August, 2013), digitaltech (11th August, 2013)
My friend has new cost 1000 us for clone. Clone works not 100 percent. Eats cas's that old programmed fine. Have to put in dump by solder and edit and sync dme/cas with older.
I bought the clone e/f and I found that I have wasted the money, I bought with the hope it will do at least what was advertised but it cannot even read the isn no in 2003 E65 cas one and I tried it on E70 and it was the same thing it said the EGS - cas was active but could not read it
I want to ask the seller if there is an upgrade to the software.
I will post updates if the seller replies.
Any more feedback?? Now price is 650eur, its worth to buy or not?
hi
from the previous coments I would say is not worth to spent a cent on it
Best regards
H.W
