Looks to me clone of bmw explorer, wether it works or not??? Anyone got feedback??
You need every tool in the book, to do this auto locksmith job.
theres some pics on carsung showing version 13.4.10 which is the very lastest version
obdmaster (26th May, 2013)
The one before that only did until 3plus was 500 work fine can not say about new.
it does not work .... guys already test china just wrote similar program mean similar GUI...
what the name of the old version u talk about
bmw scanner 2.1 or some like that
i looking into cas key making mostly add key
any suggestion i like the bmw explorer but no sure if will suit my purpose since ista update
not sure .
i also look into bmw multi tool any feedback
Knowledge is the Key
it in oarnge case reads cas3plus obd2 was 500. would not read write f series but battery reset works fine. Needs fob set up by 3.1 or transponder in key works.
Lost all keys E60 tested work fine
where can u find which cas system per model and year
E60 it has to be CAS2 or CAS3 which is can be categorized as normal key programming is in all key lost situation (most BMW programmer these days does, AK300, Multi tool , AVDI ...) , the big Question is if it does CAS3+ all keys lost situation
and i was speaking few hours ago with a Mate who has the original and he says that he tested it on a CAS3+ all key lost situation and it worked, again it was original explorer
The only place success comes before work is in the dictionary.
It depends on dme/dde type because of SOPT+ function.Check official website for compatible ECU's in that version.
Did anyone try Fxxx series coding and keymaking?
It works good from CAS4
