Results 1 to 12 of 12
    Nov 2011
    Default Opel Vectra 1.9CDTI 150PS 2005 MPPS read
    Hi, could I ever look at this file ? is it correct read ? somehow it does not seem that bad checksum .... read by MPPS V12
    0281012534
    383687
    or looking for correct MPPS read if it is wrong readout of
    1037383687 origo.rar
    thanks for reply
    waldi1979's Avatar
    Dec 2010
    This file is OK. Checksum is bad, but CHKSUM is computed in writing.
    bad checksum on a original file....doubtful, get a cooret ori and compare. i wouldnt trust mpps on this one
    Netherlands
    The RSA is missing in the reading, don't use this it will kill your ECU.
    Quote Originally Posted by Libang View Post
    0281012534
    383687
    thanks for reply
    I have seen several readings made with other versions of MPPS, and same problem.
    Br.
    I bricked a couple lf those ecu s with mpps. Compare the file with a correct bdm readout. I wouldn t touch it unless you have a bdm just in case
    znoki's Avatar
    Dec 2010
    land of plenty
    I read and write a Signum (same ECU 0281012534) by clone MPPS V12 without any problem, clone Galletto 2 can't do it.
    even though 2 legs from 8 are not bonded, a spider is a still spider (93c86)
    Apr 2012
    Hi, is this your ori file, or mod file, I have an ori file, is not a same at all.
    DK Veteran obnchip's Avatar
    Dec 2010
    You can write this full read file...
    west mids, uk
    i use clone mpps for these cars lots of times without any problems.
    Some ecu's have different size file too.
    ninja
    DK- The Bogs Dollocks!!!
    NEVER SAY IT CANT BE DONE!!
    The thanks button works wonders!!
    DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
    Dec 2010
    this opel's can be with edc16 c9 and c39.i made some and i never trust in mpps read.Sometimes mpps read only 1 block but the dump including 2-3 block.I always get full read dump and write that.I try an astra with c9 ecu and cant write with mpps and even galletto2.But in other car same ecu write without problem...
    Guimaraes, Portugal
    is correct
