Results 1 to 7 of 7
    Nov 2012
    Default Opening a Denso ECU
    I have a Denso ECU made around 2003, the case is half plastic and half metal and appears to be glued together. Can anyone please give me some tips on how to open it without damaging the case, I am thinking about heating it to soften the glue, will that work? TIA James
    Autotecno2006's Avatar
    A little more info like Make & Model, post picture. Regards P.
    Nov 2012
    It looks like this one: DENSO ASTRA H 1.7 Engine Control unit | eBay there is a grey/white sealant of some sort between the black plastic 'top' of the case and the metal lower half. I did find another image on the web of a similar looking unit and it had a lot of thermal paste along one side. I'm hoping that if I heat the case it may soften the sealant.
    What car is the ecu out of exactally, Make of car, petrol or diesel & year of car. Some have to be cut & some can be heated when u tell us the exact ECU, u will get good advice. why u want to open ECU ? Regards P.
    Apr 2012
    Wonderland
    it's simple, covers are both metal, there's no plastic.
    glue isn't hard...remove the 4 screw and open in a side where's connectors are, first with a cutter, then with a little flat screw driver
    warm up a bit the ecu with a blow dryer, it's a trick that help a lot
    it's simpler than you think
    ProTuner since 1999
    kevfield's Avatar
    uk
    These are easy to remove heat lid up and flick off lid its a 1 min job i have done a few of these easy mate..
    Thanks kev
    Nov 2012
    Thanks, I'll give it a go.
