Try this +15%. CS ok Pass PM. If help you click "thanks".
blackground (13th June, 2019), imcumen (20th May, 2013)
ohh sorry 1 cs not ok. Just start with winols and will be ok.
get a pro file mate
let him see the benefit of the free stuff!!!
Because checksum was not ok, that normally happens when its done fap off by software like volta, ecusafe etc..
But anyway if you write file most tools do cks. I dont see any problem with this.
pro tuner only finish is work wend is well done !
and is work is, is life !
My work is my life ART TECH GARAGE
AS a general rule I never send a file if does not have checksum ok. it is also a proof of profesionality and that things are well done. I like to keep things clean and simple
One question. Do you use ever in your life dyno, wideband lambda or egt sensor to do your profi map? People what ask here for profi tested maps will never have this because every engine is different and is in different condition and PROFI map is made ONLY for one and only one car. Every map what can finded on internet or you have from forum is SAFE or DANGER for engine but not profi. Thank you.
yes probably u are right. but we can rather call them tested solutions than files. even if the file is not tested itself, the results on similar engine have been tested.
Bottom line is shere, profiiiiiii tuning as u say takes time and work and knowledge, i am glad to see you are helping and offering it for free
Don't take it personal i defended your free tunes in the past, you should remember.
I just say that opening a file in winols show sometimes traces of the tools used to make the tune, and now don't tell me ecm cracked versions are best tool to do this job. Good for a free tune? Yes, but can't pass for professional tune if you relay on the final user interface to correct the checksum. What about if your free file with wrong checksum is programmed by desolder psop and a flash programmer? Or the tool the user has is not able to correct checksum? Your file becomes a free ecu bricker and all your effort and good intentions go downhill.
Once more, it's nothing against you
Just talking about ecm files. I know you do your best, like many other free tuners here.
Nice day
Camilo.
