Results 1 to 4 of 4
    GB
    Default EGR OPEL ASTRA H TWINTOP
    hello
    I have a problem with my astra, egr valve with error (amount too low) ..
    already tried with software ecu safe, volta and not results
    already put new egr valve and also not resulted ...
    someone can help me ..
    thank
    DK Veteran mishu_b's Avatar
    Land of Choice!
    manual solution is working ok for this car!
    Find EGR map (Desired air quantity) - in this file 1C2F78
    Turn on 16bit, HiLo, decimal and 2D mode
    Search after EGR map 4 hysteresis (25x1)
    fill the mpas with 0, correct checksum and done.
  4. The Following User Says Thank You to ominimicu For This Useful Post:
    d.rolex (12th June, 2013)
    GB
    hello
    just put the map edere?o 1C2F78 all zero?
    thank
