Results 1 to 3 of 3
    WinWoj's Avatar
    Jan 2012
    ECU City
    Default PC Link bin file load problem...
    Hi All.
    I started working with PC Link TCFI. One guy shown me the maps from my dump in this program, but they have different shape, as I seen in another software. Then I decide to try use PC Link, but here isn't load-BIN option. I see, can create maps from tempales, so I can change axes parameter, scale and its OK. But for itself bin putting, I make in excel my maps value, transform hex to dec value and copy to PC link.. Isn't exist easier way??
    1. I load my bin file in HEX Edit software.
    2. Check in ecm2001 addreses of maps.
    3. Copy range with values, i.e. 17x17 to excel
    4. In excel use hex2bin formula for all 289 values
    5. In excel use bin2dec formula
    6. In PC Link I edit axises for properly range of map
    7. I copy dec table from excel to PC link...
    Is it only way??
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    I don't understand why you don't use WinOls?
    and how do you correct checksum? and yes winols will be easier, save you all the forumlas and copy paste
