Results 1 to 5 of 5
    Jan 2013
    Default 074906032AT - help dpf off
    I need a solution for this DPF OF, I tried some files but not working, the vehicle will not start, can you help me please.
    Thanks,
    DK Veteran mishu_b's Avatar
    Land of Choice!
    manual solution is working 100% on this ECU.
    non starter is usually bad checksum, not bad DPF. but then of course in order for checksum to be bad. means it has been done by volta and stuff like that which is not soo good.
    conclusion: bad fap off, bad checksum
    Dupnitza, Bulgaria
    Here you are hiperecu
    Jan 2013
    I have done cleaning and regeneration of the filter with Vag com, thanks
