Results 1 to 4 of 4
    Sep 2012
    Default Skybox f3 factory reset
    Is there a factory reset I can do on the box or do I have to reflash the whole box again with the null cable?
    Sep 2012
    just go into menu mate but dont forget to dump everthing to usb first ........thre magicpart
    Sep 2008
    question is why a factory reset as that wipes out all your channels and sat info and the important bit we cant talk about,if its channel loss then a new scan or bouquet is needed.
    a full flash is only needed if a serious problem or update is needed.
    some boxes may have factory default/reset it will not remove firmware as only a new flash overwrites the older one.
  4. The Following User Says Thank You to cactikid For This Useful Post:
    road (24th May, 2013)
    Sep 2012
    Cheers lads,Thanks
