Results 1 to 8 of 8
    DK Veteran ghostridersa's Avatar
    Nov 2011
    Default Audi A4 RB8 help 7th byte please Tango
    Good day members of DK
    I am having a problem adding a key to a Audi RB8 cluster using Tango. I read the cluster with Dajavu and using the info put it into Tango but without success.
    Can any member please take a look at the files I have included with this post and tell me what the security bytes are or 7th byte? What am I doing wrong?I just need to add an extra key.
    Many thanks in advance.
    igorr's Avatar
    Aug 2010
    Use vag dash can to add key you dont nead to precode transponder and with tango you cant make transpponder for this car
    Nothern California
    Quote Originally Posted by igorr View Post
    which Vag Dash Can u are using for that not even sure who make original
    Knowledge is the Key
    Nov 2011
    Vag Dash Can clone and genuine does not work with this RB8 even though it has the option to add key.
    read tthe 7bite via key
    keygargoil's Avatar
    the rb8 writes the crypto to the key but it uses 12 bytes
    D6 3D 28 94 74 44 EF 8E 9E F6 34 8F
  7. The Following 2 Users Say Thank You to keygargoil For This Useful Post:
    Fallen (26th May, 2013), ghostridersa (26th May, 2013)
    Quote Originally Posted by keygargoil View Post
    This is the three key;
    pin;00505
    Nov 2011
    I don't understand what you mean the three key? (3 button key? yes it does)
    Quote Originally Posted by bolonc View Post
    pin;00505
