I use a straight ethernet cable straight from the computer to the box and a null modem cable. Always done in less than five minutes.
Using a laptop I make sure the Wireless is disabled and the LAN enabled.
Always have the box powered up when loading the software into IFA and double check your connection shows connected (if not, disable/enable/repair connection until connected shows).
Load the image into IFA, hit the start icon, when told to power up the box hit ok then power off and straight back on. (Having the power on then powering off and back on is important)
Here is the IFA I use:
http://www.4shared.com/file/95416732/5f7ba6e9/dbox_ifa.html
