Results 1 to 7 of 7
    Feb 2013
    Default ME3.8.3 adapt bigger throttle from VR6 on 1.8T AGU
    Hello like in the title, i try to remove the bottleneck throttle by using the bigger one from VR6. But car cogs around and is not really nice to drive. Can somebody give me a hint what maps or constants to change?
    The ECU has the code 06a906018r or 0261204673.
    here a the cars dyno three days ago with stock throttle.
    Big thanks in advance
    Nov 2012
    smartville in front of a OBDplug
    Read the serial eprom
    The adaptation must be inside
    Nov 2012
  4. The Following User Says Thank You to kennfeld For This Useful Post:
    cruuz (25th May, 2013)
    Feb 2013
    Hi vielen Dank
    is it at 0x43 ? Idle torque offset?
    Nov 2012
    strange file that you have for a immo off 4 bytes change you haven even other ecu numbers with your immo off
    Feb 2013
    yes it is a 24C02 with 2K => 256 bytes and immo off but without immo off it doesn't work too.
    here is the original:Eeprom_3.jpg
    Feb 2013
    i did the adaptation by increasing IPDK voltage to max. value of almost 5V. now car runs better but idle speed is about 1350rpm and doesnt come down. Any hints?
