Results 1 to 4 of 4
    Default Trouble updating to V3.2 software
    I am trying to update my V3 box to V3.2 software so i can install the latest images but im getting a problem.
    I am using a Win XP laptop which has a serial port. I have switched off the vu+ and connected it to the serial power via the serial lead and the board that came with the box.
    I then open the software which says OPEN SERIAL SUCCESS. I then open the bin file and switch on the box from the back. But nothing happens, it does not flash.
    The following screenshot shows this;
    What am i doing wrong?
    Sep 2008
    dont you update vu boxes by usb only,dont think you use a null modem cable.
    Yes you do if you want to flash an image. Im trying to update the box with the V3.2 firmware which is different.
    digicon's Avatar
    Quote Originally Posted by cactikid View Post
    Its a Clone Duo which requires RS232 update for the Kernel, Official receivers do everything through the USB
  5. The Following User Says Thank You to digicon For This Useful Post:
    cactikid (26th May, 2013)
