that is beacuse it s getting to much pressure, you need to raise boost limiter. Can you diag, and see live data, how much peak pressure are you getting ?
hello.
I have a astra with a engine swap...basically the 100bhp has been removed and a lower bhp engine fitted with a wastegate turbo....now the astra drives fine.but i get fault code P0234 and i get limp mode...can anyone help me to remove fault code and limp m,ode from ecu..1037374425- ASTRA.rar
MAGPRO X17--AT-200--SCANMATIC BENCH--PCMFLASH--MITSUBISHI MUT-III---OPENPORT 2 MMC FLASHER
pablo1971 (26th May, 2013)
i have already raised the boost limiter+svbl...this didnt make much difference.
but i will do diagnostics on boost pressure-thanks
