Results 1 to 10 of 10
    DK Veteran badisan's Avatar
    Default I need help for remove DPF EDC16C34 Citrone C5
    Could someone help with removing the DPF from this Citroen 5
    0 281 011 561
    9653958980
    edc16c34
    EcuSafe don't work.
    Best regards
    xanubysx's Avatar
    Sep 2010
    EUROPE
    Use VOLTA...
    Do not forget to THANKS !
    SWIFTECH FULL
    ECM Titanium FULL
    KESS V3
    AUTOTUNERS
    B-FLASH
    WINOLS
    TOPDONE
    AUTEL
    FILE SERVISE .. web under construction
    Mar 2013
    here you go
    dpf off ok
  4. The Following User Says Thank You to lucim12 For This Useful Post:
    same1 (23rd May, 2016)
    Mar 2013
    volta don't work on this ecu
    DK Veteran mishu_b's Avatar
    Land of Choice!
    you need manual solution for this issue!
    Thanks Lucim but your dump don't work.
    Please help
    Best regards
    Babos's Avatar
    Mar 2012
    Good solutions is not for free!!
    In this forum is many software free who made dpfoff same times corect same time no try and maybe this working for you.
    Best regards.
    Mar 2013
    what errors are you getting ?
    in my car worked perfect with this switches.
  10. #9
    Top Poster totalfree's Avatar
    Hi.
    DPF off
    badisan has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
    Press the button if my post was helpful.
  11. #10
    Default C4 1.6HDI 80KW remove DPF
    BOSCH EDC16c34 cit c4.rar
    C4 1.6HDI 80KW
    remove DPF EDC16C34 9656840980
