Can somebody pleeese tell how to uninstall Autodata in vista os????? I allready uninstalled adcd and adcd temp, but when i try to run 3.18 it tells me that a older version is still installed. Thank?s on advance
Now, try this way again. Delete Autodata limited folder at C:\ProgramData. Then try to install again. If still doesn't work you need to delete at registry for all autodata left behind. Click Start,
type regedit in the start search box. Select File then choose export and save as Before Regedit ( incase you do something wrong then you can import back). Select Edit then choose Find and type autodata in the search box. Delete all autodata file in registry. After every thing done, reboot and install Autodata again. Good luck.
Sorry to jump in on a thread but when i install autodata i get not a valid integer value could u help me. many thanks
just contine by pressing ecsape m8, till it loads
You need every tool in the book, to do this auto locksmith job.
Thinks OBD u leg end , took ages but worked a treat, i owe u one!
Just delete the folder, and that she should Net. Framework 3.5.
